'97 Disco, oil or grease in the swivel joint?
Not all D1's have a drain/level hole. Just cram about a liter of oil in the swivel. Grease if your seals aren't good.
Sounds easy. I am going to remove some shims as well from the locator pin to see if I can tighten up the swivel bearings. I guess what you guys are saying is that there should be a seal in place, from the factory that separates the swivel lube, from the differential lube.
About the bad cat code.. I came across this thread where a guy modified his 02's to trick the ECM into thinking the cats were still good:
P0420, P0430 - '04 Dii Hse - Land Rover Forums : Land Rover and Range Rover Forum
sorry to piggyback on this? but what was the cutoff for grease/oil from the factory? pretty sure mine has grease, there are two "genuine land rover swivel grease has been applied" stickers under the hood on my truck. Can I just buy more of if and slam it in there without servicing the whole thing?
Yes you can
If you have the small drain plug it looks like this Drain Plug - Swivel Housing (Part # 236070 ) - Land Rover swivel ***** & parts from Atlantic British
RE: " I am going to remove some shims as well from the locator pin to see if I can tighten up the swivel bearings" This is not going to end well. Your next post will be "Why do I have DEATH WOBBLE???" SEARCH it.
And this vid answers a $hitload of questions and show the seals(1:16 is the stub axle seal)
And this vid answers a $hitload of questions and show the seals(1:16 is the stub axle seal) Swivel pin housings fill, level and drain plug.differences, one shot grease and EP90 - Land Rover - YouTube
