'97 Disco, oil or grease in the swivel joint?
Old Feb 10, 2015 | 07:10 PM
stephenspann27's Avatar
Thanks Tom.
I just took a peak at my front axle. I see the fill hole for the swivel joint, but I don't see a drain hole, or a "level" hole as I saw in the video you posted.
Just checked the code on my CEL, p0420, I guess I'll have to replace the cats as well.
Old Feb 10, 2015 | 07:26 PM
fishEH's Avatar
Originally Posted by stephenspann27
Thanks Tom.
Not all D1's have a drain/level hole. Just cram about a liter of oil in the swivel. Grease if your seals aren't good.
Old Feb 10, 2015 | 08:26 PM
Sounds easy. I am going to remove some shims as well from the locator pin to see if I can tighten up the swivel bearings. I guess what you guys are saying is that there should be a seal in place, from the factory that separates the swivel lube, from the differential lube.
About the bad cat code.. I came across this thread where a guy modified his 02's to trick the ECM into thinking the cats were still good:
P0420, P0430 - '04 Dii Hse - Land Rover Forums : Land Rover and Range Rover Forum
Old Feb 10, 2015 | 09:09 PM
MM3846's Avatar
sorry to piggyback on this? but what was the cutoff for grease/oil from the factory? pretty sure mine has grease, there are two "genuine land rover swivel grease has been applied" stickers under the hood on my truck. Can I just buy more of if and slam it in there without servicing the whole thing?
Old Feb 10, 2015 | 09:17 PM
OverRover's Avatar
Yes you can
Old Feb 10, 2015 | 09:20 PM
OverRover's Avatar
Thanks Tom.
If you have the small drain plug it looks like this Drain Plug - Swivel Housing (Part # 236070 ) - Land Rover swivel ***** & parts from Atlantic British
RE: " I am going to remove some shims as well from the locator pin to see if I can tighten up the swivel bearings" This is not going to end well. Your next post will be "Why do I have DEATH WOBBLE???" SEARCH it.
And this vid answers a $hitload of questions and show the seals(1:16 is the stub axle seal)
Old Feb 10, 2015 | 09:52 PM
fishEH's Avatar
And this vid answers a $hitload of questions and show the seals(1:16 is the stub axle seal) Swivel pin housings fill, level and drain plug.differences, one shot grease and EP90 - Land Rover - YouTube
Actually pulling a shim or two usually helps death wobble.
Old Feb 10, 2015 | 09:58 PM
OverRover's Avatar
" Actually pulling a shim or two usually helps death wobble " On a truck w 200K miles I hope so. I say just pull this B$ apart and fix it right... & be done with it. I think you would agree this is more labor/time than it is money to set this problem straight.
Old Feb 10, 2015 | 11:44 PM
That video is perfect! Awesome information here. I want to thank each of you for taking the time to help me out.
cheers!
Old Feb 11, 2015 | 12:02 AM
Since I only have a fill plug, and no drain or level, that should mean my came with grease. According to the video, and since oil drained out, I either have a bad axle seal.. or grease sort of turns into oil after being in a CV joint for 200k.
