97 Disco replacing fuel lines
Old May 20, 2011 | 08:07 PM
coldstart's Avatar
Default 97 Disco replacing fuel lines
I noticed a small leak today that was gas it was running down the frame in the left wheel arch. I noticed that the fuel lines run on top of the frame and you really can's even see them .What kind of chore is it to replace them and what is the best line to use thanks
Old May 20, 2011 | 09:01 PM
Talk to DannyLee, he replaced his from the fuel tank to the engine.
Old May 20, 2011 | 09:07 PM
ShadowMerchantBC's Avatar
Just got to love this forum! It just so happens that I to am getting ready to replace one of my fuel lines in my disco, and need advice on the procedure!!! I'm all ears
I'll send Dannylee a pm to lol
Old May 20, 2011 | 09:28 PM
Danny Lee 97 Disco's Avatar
Start with a search and you should be able to find my previous write-up, with lots of details and pics.
A summary follows: get a 25 foot coil of steel fuel line (5/16 diameter), forget about removing and replacing using the same routing and clamps. The old fuel line rusts really bad at each clamp.
Start at the fuel pump cover plate. Remove the existing lines, you may have to cut them off. I also replaced my fuel pump assembly at that time with a new one from Rovers North their ProLine for 100 bucks total plug and play.
I feed a few feet at a time thru the opening, forming by hand as I went careful not to kink the tubing. I have since seen a set of special pliers for forming the tubing that will prevent kinking.
Forget about the original fuel filter location as well. I routed mine straight forward and over the large round member underneath then turned outboard toward the frame, went over the top of the frame, located the fuel filter along the side of the frame, temporarily supported with cable ties. I followed the frame member forward to the engine compartment then up and splice into the rubber lines right at the fuel rail.
A 25 foot coil will do both the feed and return lines with a foot or two to spare. Buy fuel injection rated clamps and some fuel rated rubber hoses to splice in the fuel filter and the connections at the tank as well.
I did mine by myself, having a second person would be a big help since you have to feed it from the rear cargo area and pull it from underneath a little bit at a time. about fifty to 100 times up and down should get it done.
Buy good beer and fine sipping whiskey as well.
Old May 20, 2011 | 09:36 PM
jafir's Avatar
I'm not all that informed on drinking... which do I start with? Is there a write up on this as well?
For a diabetic you drink alot, you know that will kill you right?
The alcohol messes up your sugar and when you are drunk you cannot regulate yourself with insulin.
And not to mention diabetes already puts extra strain on your liver and pancreases....I'm just sayin'...(it runs in my family and I have lost several family members to it)
Old May 20, 2011 | 09:41 PM
Not on insulin, lost 50 pounds by careful intake and blood sugar is fine now. I avoid sugar. Get lots of exercise.. That is why I say Good Beer and Fine Sipping Whiskey, appreciate it in moderation.
Spike, I do appreciate your concern as well. Glad to have it, my friend.
Old May 20, 2011 | 09:49 PM
Good for you Danny.
Old May 21, 2011 | 06:29 AM
antichrist's Avatar
The blue handled pliers are probably what Danny is talking about.
I can assure you they work great.
For a bit better corrosion resistance NAPA has copper coated steel tubing in bulk
Old May 21, 2011 | 07:47 AM
coldstart's Avatar
Did you do this in a driveway or did you have acess to a hoist ,I am glad to hear you did not follow the same path ,it seems a bit obsurd I guess they would rather you have the dealer do it . Would one of those spring benders help at all and how did you fasten it to wherever Thanks
