97 Disco window problems.............
Old Mar 22, 2011 | 10:13 PM
surveyor's Avatar
Default 97 Disco window problems.............
Hello everyome....hope you are well !
Quick question for your expertise........ The front passenger side window has quit working. Upon inspection it appears the sacrificial rubber gear in the gear drive of the motor unit has stripped. Motor runs fine up and down.
Does anyone have any experience with this ? If so......what are my options here? Can I swap this out with one of the rear door motors, etc, etc........?
Thanks in advance !
Doug Lewis
Old Mar 22, 2011 | 10:55 PM
losinov's Avatar
I dont know about swapping but it would probably be easiest to go to a junk yard or contact Will tillery or JC's rover and 4x4 for a replacement. You still want your rear windows to work right? It would be a pain to remove the rear door panel anyways.
parts@jcrover.com or willtillery@roverguy.com
Old Mar 23, 2011 | 06:20 PM
surveyor's Avatar
Actually the motor itself is fine. On the motor is the gear assembley that rachets the regulator assembley up and down. There is the nylon gear that I am assuming is probably engaged by the worm gear of the motor shaft? Nested inside the nylon gear is a rubber insert which fits around the shaft which I am assuming turns a gear which engages the teeth of the regulator itself.
The problem is the core of the rubber insert has torn out of the rubber insert and no longer will turn the shaft to move the regulator. Motor turns fine up and down.....just won't move the regulator. Is this rubber insert available by itself or do you have to buy complete assembley ?
Thanks,
Doug
twoxred
Oct 4, 2021 07:07 AM
RedAustinIX
Aug 10, 2020 11:43 PM
phillman98
Dec 4, 2010 10:01 PM
jw928
Feb 6, 2010 06:51 PM
