97 discovery as mud truck
Old Mar 21, 2012 | 07:45 PM
  #21
Fletchz's Avatar
That's gives me a little faith in a discovery. I think I might give this a try....=|
Old Mar 21, 2012 | 08:52 PM
  #22
Mountain Goat's Avatar
I've driven mine through icy slush 2-3 feet deep multiple times, and mud occasionally. I wade through deep water that may or may not have mud at the bottom, but I'm not really bogging. I've driven through deep silt beds and up some of the largest sand dunes in North America. Oh and I've pulled out plenty of stuck Jeeps. This is pretty close to stock also - 2" lift, 235/85s, no lockers. Very minor trimming. These are very worthy off-road, but you have to think differently than you would in a Bronco on 44s.
In my experience, if you maintain it well and drive like a sensible human being (e.g. let the Rover do it's thing, don't show off) you'll be fine. Just take the obstacles as they come on the the trail and imagine you're on a safari (which is not hard to picture most of the time).
Best wishes with the adventure. Just ask plenty of questions about what needs to be upgraded and we will try to help. Plan out your costs carefully - $1200 or so per differential will get you full-carrier lockers and gears, assuming you don't save a bit by setting them up yourself. You'll need upgraded axles, a lift, and your choice of tires. 235/85 and 255/85 are very good on these. Most likely you'll need upgraded driveshafts as well, and buy yourself a pressure washer. You'll learn all about the mud traps these have in the frame, but they aren't too hard to clean out if you know where to find the mud.
Old Mar 21, 2012 | 09:56 PM
  #23
attackRus's Avatar
0,o maybe a good ole bronco for a mud truck....
Don't ruin a work of engineering by making it into a mud truck =D
Old Mar 22, 2012 | 05:05 PM
  #24
Jake1996D1's Avatar
ASHCROFT ASHCROFT ASHCROFT..
If you are serious about this thats all you need to know. Oh and have a load of savings stashed.
Ashcroft 4.75 gears
Ashcroft air lockers front and rear.. or just front and Detroit in the rear (I'll probably switch to Ashcroft in front soon)
Ashcroft axles front and rear and cv's
2-3" Rovertym springs and since it's a mud truck you dont have to worry about long travel shocks etc for articulation
33-35 super swampers "skinny" boggers are my fav look which are 10.50
Tom woods for drive shafts
A snorkel if you're gonna go into mud/water that goes over your hood like I do it eats engines!
And you will likely be in a better place than a lot of the broncos/blazers and be able to pull out f150s no problem
and the guy who wrote about not using a disco in the mud cause it's a piece of engineering??? You need to watch some camel trophy and watch what they do in the mud with unlocked trucks on 32s
Old Mar 22, 2012 | 05:53 PM
  #25
attackRus's Avatar
Ashcroft 4.75 gears
I don't wanna get into a fight or anything but I didn't mean don't use it it in the mud I just mean't don't lift it to the point where its useless unless in the mud.
MKO
Other
Nov 5, 2014 01:08 PM
Spencerfitch
Dec 17, 2010 10:48 AM
faturbo
20
Jan 14, 2010 06:41 PM
krispyklene
Feb 17, 2009 01:50 PM
05LandRover
Freelander
May 3, 2005 02:23 AM
