97 - Exhaust leak from head
Old Nov 15, 2014 | 05:08 PM
mmaesner's Avatar
Default 97 - Exhaust leak from head
I have an exhaust leak from the head gasket I think. I can feel the exhaust blowing out, I can hear the exhaust blowing out, is it possible for the head gasket to go on the outer edge and let the exhaust out but no coolant issues.
I checked the exhaust manifold and it seems fine.
any input on likly hood that is what it is would be appreciated and any bubble gum fix ideas would also be appreciated.
Old Nov 16, 2014 | 12:18 AM
pacopico's Avatar
8th Gear
My head gaskets blew in the exact same manner. No fixes with bubblegum, time for new head gaskets, and possibly more at 190k.
Old Nov 16, 2014 | 08:10 AM
dusty1's Avatar
That exhaust gas can groove your block or head, if you do not take care of the blown gasket.
Old Nov 16, 2014 | 10:12 PM
nuclearw's Avatar
you sure its the head gasket and not the exhaust manifold gaskets or a cracked manifold?
Old Nov 17, 2014 | 08:46 AM
mmaesner's Avatar
I pulled the exhaust manifold gaskets and there was no tracking marks on them, so reinstalled them, I can put my finger in next to the joint where the head and block join and get a very specific spot where the exhaust is being forced out (this is obviously a fast test as it is bloody hot). Any suggestions on how to confirm HG leak and not cracked manifold.
Old Nov 17, 2014 | 09:04 AM
nuclearw's Avatar
Was just curious. If you smoke you could try and block the fan in that area (some cardboard perhaps) and blow .. see where its gets blown. otherwise, maybe incense?
Out by us, I think we could tell by the vapor in the air (10deg today.. )
also, clean that area on the head, see if there are any soot deposits forming
Old Nov 17, 2014 | 12:07 PM
drowssap's Avatar
"Any suggestions on how to confirm HG leak and not cracked manifold."
if you can put your finger on the leak between the head and the block what more confirmation could you need?.
Old Nov 17, 2014 | 04:16 PM
mmaesner's Avatar
Well none actually.... I was just hoping for some other answer. This is my second disco and my second blown head gasket.
Savannah Buzz
Mar 30, 2017 08:25 PM
Disco Stew
Mar 28, 2013 09:25 PM
MoShadeTree
Dec 31, 2012 07:32 PM
old gold
Aug 10, 2008 07:41 AM
DuplinDisco
Jan 27, 2008 04:29 PM
