97 with over pressurized coolant system
Old Mar 30, 2015 | 11:08 AM
WaltNYC's Avatar
are you installing the thermostat correctly? Spring goes toward the engine block. Does it have one of those little 'jiggly' things that make it easier to bleed? That goes in the "12 o'clock position.
Old Mar 30, 2015 | 05:03 PM
mmaesner's Avatar
yep - double checked that. It is defiantly running hot, It seems steady at 200 to 205 before it spikes. I am going to try flushing the system and see if that doesn't at least help lower the running temp
Old Apr 1, 2015 | 06:31 PM
mmaesner's Avatar
ended up being plugged radiator, worth noting temp gauge in dash reads normal up to about 215 -220 before it starts moving - everyone should have an ultra gauge
kmccarthy88
Jun 7, 2015 06:56 PM
discorey
Nov 27, 2014 12:47 AM
SolbergFanBoi
Mar 5, 2012 07:05 PM
Frank4
Mar 18, 2010 08:13 PM
