ABS with center diff locked?
Old Jan 23, 2013 | 02:36 PM
binvanna's Avatar
Default ABS with center diff locked?
Is it even supposed to work with the center diff locked or does that disable ABS? Or does the ABS have two modes for locked and unlocked?
Old Jan 23, 2013 | 06:03 PM
jastutte's Avatar
I think that on the D1s the ABS is always on unless you disable it by pulling certain fuses.
Old Jan 23, 2013 | 06:19 PM
geek_IM's Avatar
There is no connection between the diff lock and the ABS. ABS is just a variable reluctance sensor used to count teeth on a sensor ring mounted to the rotor, a pump to pulse the fluid input to the caliper, and a very simple feedback loop control system to activate it. If the sensor stops counting while the brakes are being applied, but the ABS brain still gets a speed input from the VSS it assumes the wheel has stopped spinning (ie locked up) and activates the ABS pump and opens a valve to pulse the fluid going to that wheel. It does not even care what the other wheels are doing, let alone what the transfer case is doing.
Old Jan 23, 2013 | 09:05 PM
Discolife's Avatar
We still have open difs so ot doesnt really create any type of binding in the system.
ABS still works with dif lock.
Old Jan 23, 2013 | 09:14 PM
ABS on a DI is a oxymoron.
Old Jan 23, 2013 | 09:26 PM
XCELLER8's Avatar
give it time....your ABS will disable itself !
Old Jan 24, 2013 | 12:16 AM
binvanna's Avatar
really the question came up because I was reading about some of the early 4wd ABS systems like on the Mitsubishi Pajero and how they were groundbreaking because they worked with a center differential lock, but this was early 90's and I suppose by the time it was on Land Rovers the multi-mode ABS was a routine feature.
Old Jan 24, 2013 | 08:05 PM
Discolife's Avatar
I gotta laugh, the ABS on the disco I are an absolute joke, more funny than anything else. I ver literally made a fast manuever skidded, applied brakes removed my foot from the brake and and it felt like 5 seconds later the abs began to engage. My wife and I laughed
Old Jan 25, 2013 | 04:25 AM
dragonhead's Avatar
D1 ABS gives me zero confidence in the wet. I nearly slid through a couple of busy intersections with no engagement, but normal stops give me a wonderful stutter in the pedal. It is good to know that diff locks won't affect what little benefit my ABS system offers.
Old Jan 25, 2013 | 09:50 AM
geek_IM's Avatar
Just for Ss and Gs, for those who don't have them here is a link to Wabco's literaturre page:
http://www.meritorwabco.com/ProductL...roduct_level=2
Here is the troubleshooting manual for Version C
http://www.meritorwabco.com/MeritorW...ument/mm38.pdf
And Version D
http://www.meritorwabco.com/MeritorW...ument/mm39.pdf
You can tell what version you have by looking at the ABS ECU tag.
Francopacks
Apr 30, 2013 12:08 PM
Lord Wert
Dec 1, 2012 06:58 AM
SoCal Detail
Apr 18, 2010 09:02 AM
darkside
Dec 16, 2007 04:18 AM
mordor110
Dec 10, 2007 10:14 PM
