1994 disco I serpentine belt
Old Jan 22, 2013 | 10:15 PM
Fishman's Avatar
Question 1994 disco I serpentine belt
Is it possible to run a serpentine belt to bypass the a/c compressor on a 3.9. I need to replace the bearing on the a/c clutch.
Old Jan 23, 2013 | 12:34 AM
Most likely will need a different belt. I noticed that Rock Auto had them listed for both with and without AC. See attached routing page fom shop manual. Guess the tensioner will be rotated a bit.
File Type: pdf
Old Jan 23, 2013 | 05:22 AM
Fishman's Avatar
I forgot to mention I looked at the manual and found the picture but I think im going to need to change the idler pulley or the tensioner.
Old Jan 23, 2013 | 08:25 AM
Denso compressor fits 94-99 D1s. About $225 whole from places like Rock Auto. Or $35 used at a boneyard (could put in place while you take good one to fix). A spare used compressor is cheaper than a new tensioner. Guess you might be able to measure and buy a different belt, water pump has to turn in correct direction, etc. The minimum is water pump, you can drive truck for short distances (like 30 minutes) and charge the battery back up, and no power steering is a bear.
Old Jan 23, 2013 | 08:31 AM
antichrist's Avatar
Yes, you need a different idler pulley. I'm not positive, but I don't think you can rotate yours to make it work.
Old Jan 23, 2013 | 09:00 AM
EricTyrrell's Avatar
https://landroverforums.com/forum/di...ne-belt-49753/
Old Jan 25, 2013 | 10:12 AM
Fishman's Avatar
Thanks I'm going to pull the ac clutch and replace the bearing.
Old Jan 25, 2013 | 02:38 PM
I hope you saw the note about needing a D2 idler pulley.
real_tea
Aug 21, 2015 10:14 AM
SFlynn2nd
Jul 16, 2009 05:38 AM
Benhamtroll
Aug 17, 2006 11:45 AM
Thegix2
Nov 22, 2005 09:25 PM
esaycho
Oct 12, 2005 03:24 PM
