ABS Code 28
ABS Code 28
My Disco 1 has a code 28 for the ABS system.
Code 28 was for a solenoid valve which I am to understand is inside the ABS modulator.
The ABS modulator was cheap (300$) so I threw a new one in. The light went out for a short time but I am now getting the same code.
Any suggestions on where to go from here?
Thanks so much!! I'm toatlly new to Land Rover.
Thanks for the insight guys!! I installed a new one (300$) not used and I'm getting the same code.
I have discovered that there are ABS relays on the passenger side of the vehicle.
I can not figure out which ones are the one for the ABS. I have Mitchels on Demand and the colors for the relays wiring does not match so I don't know which one to check.
How do I tell which is the ABS relays?
Thanks so much!!
Now in the middle of testing my oil light came on. I dropped the pan and it's full of sludge and the oil sump is clogged. I'm cleaning it out now, think I'll be ok then.
Thanks so much!!
I got this out of the manual was kindly proved by member here (thank you!). Does anyone know where I can find the "Electrical Trouble Shooting Manual"?
Electrical wiring is provided as necessary with system
relays and fuses. Discovery Electrical Troubleshooting
Manual gives the location and wiring circuits of these
components."relays and fuses. Discovery Electrical Troubleshooting
on
DiscoBenjamin
10-14-2011 05:53 PM
