ABS Code 28
Old Feb 1, 2011 | 12:48 PM
kehoeautomotive's Avatar
3rd Gear
Default ABS Code 28
My Disco 1 has a code 28 for the ABS system.
Code 28 was for a solenoid valve which I am to understand is inside the ABS modulator.
The ABS modulator was cheap (300$) so I threw a new one in. The light went out for a short time but I am now getting the same code.
Any suggestions on where to go from here?
Thanks so much!! I'm toatlly new to Land Rover.
Old Feb 1, 2011 | 12:50 PM
Chris-bob's Avatar
Check your grounds for the abs modulator. That's a good place to start. Other than that, I don't know. Download the RAVE if you havn't done so already. Great resource for all your Land Rover needs.
Old Feb 2, 2011 | 03:40 AM
jbriggs's Avatar
Is you anti-lock light on? It needs to be reset after changing the part which is done by the dealer or you can us the blink method I've attached and save $100.
Old Feb 2, 2011 | 10:30 AM
If you threw in a used one, chance are it has the same problem, that is why it was so cheap. New ones are around $200 from the dealer, that is why most people save a lot by buying a kit and doing a rebuild.
Old Feb 2, 2011 | 01:04 PM
3rd Gear
Thanks for the insight guys!! I installed a new one (300$) not used and I'm getting the same code.
I have discovered that there are ABS relays on the passenger side of the vehicle.
I can not figure out which ones are the one for the ABS. I have Mitchels on Demand and the colors for the relays wiring does not match so I don't know which one to check.
How do I tell which is the ABS relays?
Thanks so much!!
Now in the middle of testing my oil light came on. I dropped the pan and it's full of sludge and the oil sump is clogged. I'm cleaning it out now, think I'll be ok then.
Old Feb 2, 2011 | 01:12 PM
3rd Gear
Electrical wiring is provided as necessary with system
relays and fuses. Discovery Electrical Troubleshooting
Manual gives the location and wiring circuits of these
components."
I got this out of the manual was kindly proved by member here (thank you!). Does anyone know where I can find the "Electrical Trouble Shooting Manual"?
Old Feb 2, 2011 | 02:02 PM
Chris-bob's Avatar
components."
Download the RAVE. It's in there.
bosshogt
Jan 20, 2014 09:29 PM
hatt53
Mar 27, 2013 05:16 PM
pixel
Mar 5, 2012 12:29 PM
sayeedA
Nov 15, 2011 11:02 PM
