ABS Sensors - repairing?
Hi,
I am sure that this may or may not have been covered. I was unsure about the source of this tip, but I recall reading it somewhere.
I read that more than half of the time the ABS sensors become a little loose or dislodged and require a gentle tapping to get them back into place, which usually make the ABS light on the dash go out.
Does anyone have experience with this type of repair?
Where'd you find the grommets at? It took some serious Sherlock Holmes sh*t on my part to get part numbers for the Audi part #'s for the grommets that are the same Rover uses.
Would it be these parts below from a 1992 Audi 100 A6/V6?
This is from a thread at Discoweb and an Audi forum
This grommet is closest to the Discovery front of vehicle
Audi OEM part number: 4A0-611-817-A / 4A0611817A
This grommet is closest to the Discovery firewall
Audi OEM part number: 893-611-817-B / 893611817B
Could the "rotted" grommets allow air into the system, or create air pockets with the leaking which would lead to ABS issues?
