ABS Sensors - repairing?
Old Sep 20, 2013 | 05:58 PM
archaeology_student's Avatar
Question ABS Sensors - repairing?
Hi,
I am sure that this may or may not have been covered. I was unsure about the source of this tip, but I recall reading it somewhere.
I read that more than half of the time the ABS sensors become a little loose or dislodged and require a gentle tapping to get them back into place, which usually make the ABS light on the dash go out.
Does anyone have experience with this type of repair?
Old Sep 20, 2013 | 06:08 PM
fishEH's Avatar
I usually pull them out, clean, and tap them back in. Well, I DID do that back when I cared about ABS. Now my modulator and dash light are removed and I don't care.
Old Sep 20, 2013 | 07:51 PM
TOM R's Avatar
I have never had the ABS lite on steady but the ABS used to come on whenever it wanted mostly making turns and it sucks truck will not stop, I finally removed the fuse under the hood I may try to fix at a later date and reinstall the screw in fuse
Old Sep 20, 2013 | 10:26 PM
Jon Pitts's Avatar
Mine was on all the time, grommets in the master cylinder reservoir were rotted out. I never even noticed till I found a puddle under the master one day leaving work. New grommets, bleed brakes, no light.
Old Sep 20, 2013 | 11:10 PM
fishEH's Avatar
Where'd you find the grommets at? It took some serious Sherlock Holmes sh*t on my part to get part numbers for the Audi part #'s for the grommets that are the same Rover uses.
Old Sep 21, 2013 | 08:05 AM
Jon Pitts's Avatar
I went through the same thing, if I remember right I found them on ebay from a Audi parts supplier.
Old Sep 24, 2013 | 05:37 PM
Wink
Would it be these parts below from a 1992 Audi 100 A6/V6?
This is from a thread at Discoweb and an Audi forum
This grommet is closest to the Discovery front of vehicle
Audi OEM part number: 4A0-611-817-A / 4A0611817A
This grommet is closest to the Discovery firewall
Audi OEM part number: 893-611-817-B / 893611817B
Old Sep 24, 2013 | 06:08 PM
fishEH's Avatar
Hey that's my Dweb thread!
I thought maybe you had found them at AutoZone or something, haha.
Old Sep 25, 2013 | 03:53 AM
Thumbs up
I just realized that! Thank you for the hard work and the info
Old Sep 27, 2013 | 12:46 PM
Question
Question for the above scenario.
Could the "rotted" grommets allow air into the system, or create air pockets with the leaking which would lead to ABS issues?
