AC Fan Bypass
Find the positive wire running to both the fans (between the battery and headlight and runs up beteween the radiator and a/c condenser). Cut it and add a 30a relay controlled by a lighted switch in the cab. Or you can use a wire that is only on when the ignition is on so you won't forget to turn it off and come out to a deat battery.
twilightcall
03-04-2018 06:55 PM
rover1978
09-26-2009 09:05 PM
