AC line blew out.
Old Jun 17, 2018 | 06:19 PM
jimvw57's Avatar
Unhappy AC line blew out. fixed w/pics
Found that my AC system was empty and tried charging it today in the 90 + degree heat. As it was just about full, I heard a big hiss and all the R134a came out from below the coolant reservoir. Must be the reason it was empty to begin with. Going to wait until it gets a bit cooler outside to find what went boom.
Old Jun 19, 2018 | 09:25 AM
bwpatton1's Avatar
If its the crimp on a hose then take the hose off and take it to a hydraulic shop and they can make you a new hose with the old bits. Should be about 35-45$
Old Jun 20, 2018 | 12:51 AM
jimvw57's Avatar
solid aluminum tube from connector behind coolant tank, under tank to front behind grille. Broke right by the clip holding it to the body.
Old Jun 20, 2018 | 09:19 AM
bwpatton1's Avatar
Ahh, I don't know of any way to repair that. Best to get a used part from Will Tillery or maybe Paul Grant?
Old Jun 21, 2018 | 09:08 AM
jimvw57's Avatar
Thought I'd give this a try. rated for A\C repair and up to 2400 psi.... if it doesn't work, I will have to take apart the front of the truck and see if there is a connection n the condensor. Just not to sure about removing the rusty brush guard...
Old Jun 27, 2018 | 08:53 AM
bwpatton1's Avatar
Let us know how it works, I do love AC work
Old Jun 28, 2018 | 12:25 AM
jimvw57's Avatar
I will have to do a bit of re-routing as the break is right in a 90 degree bend. Luckily it is out in the open once the coolant tank is moved
Old Jul 6, 2018 | 06:51 AM
jimvw57's Avatar
The line does a route behind the shock tower so the bend will be difficult to re-route. I guess i will need to find a replacement pipe, or at least some more tubing I can splice in. anybody got a D1 they are parting out with a line on it??
Old Jul 8, 2018 | 10:14 PM
jimvw57's Avatar
Ok,the line splice isn't going to work so I came up with another plan....
Amazon Amazon
This should have a good chance of working out. We shall see when it arrives...
Old Jul 14, 2018 | 12:01 PM
jimvw57's Avatar
Installed the splice hose and it worked good! pulled a vacuum for about an hour and charged up. Blowing cold air now.
This is where the tube broke. right at the edge of the clamp
https://landroverforums.com/forum/at...1&d=1531587515
With the splice installed
Make sure you use a 8 MM splice kit. the 5/16 is close but won't fit.
Attached Thumbnails AC line blew out.-dscn2044.jpg   AC line blew out.-dscn2045.jpg
