Adaptive value reset
Old Oct 24, 2020 | 12:37 PM
  #21
jimvw57's Avatar
Originally Posted by logan_gibson
Youre welcome to send them over to me and I can pair them all up.
I have an ECU and an alarm that I had problems with, and replaced both. Not sure what the issue was or if they can be reset. I wouldn't mind having a spare set around
Old Oct 24, 2020 | 12:52 PM
  #22
logan_gibson's Avatar
you can pm me.
I can see what the issue is and fix them, then send back out.
Old Oct 25, 2020 | 10:21 PM
  #23
GA D90's Avatar
6th Gear
Originally Posted by _ExpeditionMan
Is there a FAQ on robertf's app for dummies? Additionally, is this app only for resetting adaptive values?
Does anyone here have experience with a different scanner (hawkeye, icarsoft, etc.)?
By no means am I an expert... but the app absolutely works to reset the adaptive values related to throttle. Normally you could only do this with a high end tool to get into the ECU.
The app is very simple, what you see on the screen shots is all there is to it. You connect to the OBD device, hit reset on the app... hold your breath, that’s it !
I tried the iCarsoft, nice scanner for the money, reads lots of speciality codes for Rover, but can only reset fault codes, not idle or throttle pos., Same thing with Hawkeye, didn’t try it but got that from there support.
For $60 Bluetooth ODB dongle, and the free app that comes with it, and the GEMS app , you’re good to go!
Spencerfitch
Nov 14, 2017 04:45 PM
PNW Disco
Aug 29, 2017 12:11 PM
bushpilot
Dec 11, 2012 03:57 PM
rhino_e28
Sep 28, 2010 12:38 AM
Spencerfitch
Sep 20, 2010 03:25 PM
