AEL pump in non-AEL truck
Got the cover off in the trunk and can see the pump now. Doesn't look like the one connector would be a problem and the 2nd port in the AEL pump could just go unused but there is a vacuum hose with no where to plug into so I think that will be an issue.
That said, if I am testing voltage correctly, I am only getting 5V or so to the pump .... Either I am testing the wrong pins or else I have some type of a problem with wiring.
5V would be the float side of the plug. You don't have to change the whole cage with the AEL, just swap the pumps. Also the pump circuit only runs for a few seconds, it takes two people to check it, someone to turn the ignition and the other testing the plug.
Wow, that baby got hot....... nice. Mobile Rover bomb.
