Ah, the joys of window seal replacement...
Old May 3, 2011 | 06:35 AM
Dodger's Avatar
Default Ah, the joys of window seal replacement...
So my new rear window seals came in for British Atlantic (just over $100 for both sides shipped to the house). Given it has been raining cats and dogs here in Tennessee I figured I would change them last night between the storms. I should make it know that I have installed many a Volkswagen windshield with a similar style seal. So after getting the first window off I placed the seal on the window, placed a string around the inner seal lip and had my son hold it up against where it goes. the rest of the story involves words I can't type here, and many different plastic body panel tools. Needless to say it start raining before we were done and I only got one seal done. However, it does look great and no longer leaks on that side. I guess I will do the other on today...
Dodger
Old May 3, 2011 | 08:37 AM
groundandpound's Avatar
For some silly reason, the passenger side tends to go easier than the drivers...
Good luck!! Oh, and if you were not using a silicon spray lube, or some liquid soap, try it on the next one!!
It only took me about 15 minutes to replace mine...and the $7 Double Suction Cup holder for the glass from Harbor Freight was BRILLIANT!!
colemtd
Mar 25, 2022 06:48 PM
yloDiscoII
Feb 10, 2010 10:03 PM
Spike555
ROAMING WITH FRIENDS
Aug 13, 2009 04:17 PM
sloppyjoe
Nov 13, 2008 07:40 AM
blue_bird0205
Jan 12, 2008 04:07 PM
