Air conditioning help Disco I
Hey guys, need a little help here. My air conditioning isn't working in my disco. I have no power to the compressor clutch. If I jump from battery to the compressor coil it works and blows Ice cold, but I can't find an accurate wiring diagram or the location of the relay that controls the compressor. Can anyone out there give a guy a hand??
I can't download the manual because I don't have a disc burner on my computer.. Any other ideas on the wiring diagram or location of the relay? If I knew where the relay was located I could check to make sure voltage is comng in and going out of the relay. As for the switch I tried to pull it out and I can't get the climate control out to check the switch.
