Air Conditioning Switch
Old Nov 24, 2020 | 06:41 PM
grahamggggg's Avatar
Default Air Conditioning Switch
I have a 98 Disco and I believe my switch for the A/C on the climate control panel is bad. I removed and replaced it with a switch from a junkyard car, but I believe that switch was bad also. I know the A/C works because my existing switch would turn on the AC (ice cold) with some fiddling up until recently when it stopped working entirely. All fuses are good...
It seems that these switches are not readily available on eBay or elsewhere, however the air recirculate switch, which appears to be identical other than the face plate, is readily available. Does anyone know if I could simply replace the AC switch with a new recirculate switch and if it would work? Then I could possibly take the snowflake cap off my old switch and put it on the new one - or just have two recirculate buttons...as long as the A/C works I don't really care...
I would simply swap the existing air recirculate switch with the A/C switch to test it, but my air recirculate switch doesn't work either...along with half the other switches on this car.
Old Nov 24, 2020 | 08:03 PM
Best4x4's Avatar
D2 rear AC switch = identical, just pop the cover off and slap on the snowflake one.
Old Nov 24, 2020 | 08:32 PM
Thank you very much - I just ordered a D2 rear AC switch on eBay so I'll give it a shot.
Old Nov 25, 2020 | 03:20 PM
WaltNYC's Avatar
You can take that switch apart like any other switch on the dash. Over time the corrosion builds up and they lose contact. I would also test out the bulbs because taking the dash apart to get to those two switches is a pain. I messed up and didn't test the bulbs and eventually I will need to do it again.
Old Nov 25, 2020 | 03:57 PM
Do the switches not function if the bulb(s) are blown? I have the dash pulled apart right now, so it's easy enough for me to test different things while I wait for another switch to be shipped to me...
In my (limited) experience, cleaning the switches is a huge pain and I'd rather not do it if I can avoid it.
Old Nov 28, 2020 | 07:43 PM
WaltNYC's Avatar
They will work even if a bulb is blown. Yes, it is a pain in the ***, but I have more time than money so that's what I do.
Old Dec 1, 2020 | 07:19 PM
The D2 rear A/C switch works like a charm...thanks again!
LR4play
LR4
Jul 17, 2020 05:33 PM
azsparrow
Aug 23, 2016 12:28 PM
mjbrox
Dec 10, 2014 09:35 PM
ktm_525
Sep 4, 2012 10:43 AM
chad420
Oct 26, 2009 03:50 PM
