Air intake temp, engine temp, snorkle
Old Jun 16, 2014 | 01:57 PM
bearskinrug's Avatar
Default Air intake temp, engine temp, snorkle
Just got an ultra gauge cuz I noted my temp gauge rise just above midline the other day when I left the truck parked for 20min or so and Ac going full blast. The little needle hovered above the wavy water lines and dropped right back down after I turned the Ac off and drove away. UG reads temps up to 210 around town and air intake temp up to 160. It's about 90 degrees here in Albuquerque. Wondered if intake air temp correlates with engine running temp, and has anyone seen lower running temps with a raised air intake? Anybody have before and after numbers after installing a snorkle? This is kind of an academic question, I understand healthy cooling system is the most important issue.
Old Jun 17, 2014 | 03:07 PM
MonteroMan's Avatar
'Just got an ultra gauge cuz I noted my temp gauge rise just above midline the other day when I left the truck parked for 20min or so and Ac going full blast.'
Seems exactly, perfectly normal to me as there was no cooling flow over the engine as when you are driving.
Those temperatures you mention are quite OK because it is a pressurised cooling system and low speed / no speed in summer Moab will cause that.
The inlet air temperature does not have so much effect on combustion temperature and the resultant engine temperature. If you had NO cooling air sucked through the radiator (where the engine coolant is being cooled) the engine would become very hot. If the fan sucks hot air, but at least somewhat cooler than the coolant in the radiator, the engine will be warmer than when very cold air is is doing the cooling.
Your accurate gauge was just accurately displaying the laws of physics regarding air flow and heat exchange.
The snorkel causes all kinds of restrictions and internal turbulence to the cooling air and is not reccommended for normal use - its original design was to move the air intake above where water can ingress when crossing flooded river passings in Africa.
sloppyjoe
Feb 14, 2011 06:11 PM
rj95lss
Jan 29, 2010 11:13 PM
Chrisinhouston
Dec 13, 2007 08:43 PM
96broncoman
Oct 16, 2007 07:02 PM
uctdiver
Aug 18, 2007 05:26 PM
