Allmakes4x4 brake line end different
What part number did you order? Rear line should be NTC3458. That end goes into NTC7291 and the OE line is correct not the ALLMAKES.
If you are stuck go to Advance Auto and get a DORMAN H620301
Dorman Products - H620301
OR NAPA http://www.napaonline.com/Catalog/Ca...310_0361244646
Take a look at the pics you will see the end you need.
my invoice has the correct PN, so does the bag the lines came in. i left a message with AB, i'll be speaking with them in the AM. i also ordered the hard brake line kit since i really didnt have the time to cut and flare fittings (nor did i want to) and the fitting going to the body side of this line is an incorrect bubble flare... it should be an inverted flare.
it would be much simpler if i could run to the parts store and correct it, but with this truck that unfortunately isnt the case.
both the allmakes and the OEM line were like that, and the OEM line that came off was (and has to be in order to seal) an inverted flare
dealing with AB has been disappointingly frustrating. i'm stuck until monday to speak with someone about this and i'm still out of a truck. i cant reuse my stock rubber hoses bc the threads are flattened on one end, and i should probably order a new pipe junction since this one is pretty rusty inside. i'll end up cutting and re-flaring the hard line myself.
