alternator replacement... any tid bits of cleverness?
Old Dec 10, 2019 | 09:25 AM
WaltNYC's Avatar
Default alternator replacement... any tid bits of cleverness?
Well my original alternator seems to have bit the dust. Will do some testing when kids gets home from school to confirm.
Battery is brand new.
I will be installing a used unit which I bought from Will a few years ago in anticipation of this day. It has been sitting in a box in the 'parts corner' of a closet in the apartment since I received it.
So it should be a very easy bolt off, bolt on, but is there any little tips that are worth following? A shot of PB plaster or something of the sort in a specific area? Any little things to address while I'm there?
Old Dec 10, 2019 | 10:45 AM
Friday Night Disco's Avatar
After you removed the alt, tap the expansion sleeves back into the bracket
Old Dec 10, 2019 | 01:07 PM
whiskeynipple0088's Avatar
easy peasy.
Prolly the only straight forward replacement on these trucks
Old Dec 10, 2019 | 02:27 PM
WaltNYC's Avatar
Originally Posted by whiskeynipple0088
easy peasy.
Well ...brake pads (not rotors though).
It is supposed to start raining just when I'm about to start. And of course it is already dark. Fun times.
Old Dec 11, 2019 | 07:35 AM
WaltNYC's Avatar
The rain held off the the most difficult part of the job was getting the replacement alternator to fit into the bracket. Tapping the sleeve did the trick.
For future reference to help those searching the forum, this is what lit up on the dash when the alternator failed...
The battery, SRS, and anti-lock light are illuminated and the low fuel level light was flickering. The tachometer, which is fed by the alternator, was not functioning.
Attached Thumbnails alternator replacement... any tid bits of cleverness?-bad-alternator-dash.jpg
discobob
Jun 4, 2015 11:59 AM
JPSpen
Feb 25, 2013 05:53 PM
edh
Aug 23, 2012 06:59 AM
Fireman
Feb 4, 2011 08:14 PM
willmjck
Dec 29, 2010 08:38 PM
