Alternator Replacement
Old Jun 3, 2015 | 05:47 PM
discobob's Avatar
Default Alternator Replacement
Alternator is dead. I've disconnected all my cables, and removed the two bolts from the support bracket. It will not budge. What am i missing? TIA
Old Jun 3, 2015 | 06:11 PM
Joemamma1954's Avatar
Get a screwdriver and move the little spacers that are holding the alternator firmly in the bracket. It is possible to use a bar to pry alt up and out, but releasing the pressure from those spacers or whatever they are called will allow easy removal.
Old Jun 3, 2015 | 06:14 PM
discobob's Avatar
I assume you mean the bushing like things in the bolt holes?
Old Jun 3, 2015 | 06:17 PM
Yes, could not remember what they were called.
Old Jun 3, 2015 | 06:19 PM
They need to be moved only a little, and will move back in place when tightened
Old Jun 4, 2015 | 10:31 AM
discobob's Avatar
Hate to drag this out. Do I tap them inwards, or pull them outwards. They wont budge.
Old Jun 4, 2015 | 10:48 AM
pinkytoe69's Avatar
Just use a beefy screwdriver or pry bar and lever it out. Hammer your pry-device a bit if neccessary.
Old Jun 4, 2015 | 10:52 AM
Fast951's Avatar
Spray a little bit of rust-buster or other penetrating oil on the bushings as they have a tendency to freeze in place. You should be able to carefully pry the alternator out after the bushings soak for a bit. You will have to work the alternator back-and-forth. Once the alternator is out you can use a pair of Channel-Lock pliers and a socket with the open end positioned on the front of the alternator bracket to squeeze the bushings out before reinstalling the new or rebuilt alternator.
Old Jun 4, 2015 | 11:59 AM
drowssap's Avatar
B/A Screwdriver
dspitznagel
Mar 11, 2011 05:20 PM
JumPeR04
Dec 17, 2009 07:57 PM
mgabriel
Dec 11, 2008 11:53 PM
wizardmagu
Oct 23, 2008 10:56 PM
wizardmagu
Engine & Internal
May 31, 2008 08:50 AM
