alternator swap q
Old Jun 13, 2015 | 08:04 AM
TOM R's Avatar
Default alternator swap q
Got an alternator from a 1996 rangie with gems engine, shop confirmed its 120 amp, do I need to change the pulley or anything or is this direct drop in bolt up on my 1998 d1?
Old Jun 13, 2015 | 09:29 AM
antichrist's Avatar
The pulley is a bit smaller in diameter. What that means is it will charge at a higher amperage at a slightly lower engine rpm.
Been running one on my '95 like that for years.
Old Jun 13, 2015 | 09:43 AM
TOM R's Avatar
Cool that's what I wanted for the winch, not bad for iirc $20
Alt shop ran on bench for a while said works great
Old Jun 13, 2015 | 10:03 AM
robertf's Avatar
pulley is the same on 4.0. only the 3.9 serpentine used a different size
Old Jun 14, 2015 | 12:26 PM
TOM R's Avatar
All done works great, will this throw off my tach?
Old Jun 14, 2015 | 04:43 PM
jafir's Avatar
You should be able to check with that scanner you've got. The RPM signal from the live data will be from the crank sensor while the tach is from the alternator.
Old Jun 14, 2015 | 05:42 PM
antichrist's Avatar
If the pulley is the same size it won't. On my '95 it did a bit, but I didn't really care.
Old Jun 14, 2015 | 06:24 PM
TOM R's Avatar
Well the ug and teach are close enough, pulley looks same without measuring it
Old Jun 19, 2015 | 12:24 PM
Buddy Lee's Avatar
Does the '95 not get it's signal from the coil? Or does that only go to the ECM?
Old Jun 20, 2015 | 07:33 AM
ihscouts's Avatar
Read the 95 ETM on "Starting and Charging". "Voltage pulses are taken from the engine Generator (Z106) and are generated when the engine drive belt turns the Generator pulley. The Tachometer responds to the frequency of the voltage pulses......".
bennyb43
Dec 11, 2013 08:17 AM
JumPeR04
Dec 17, 2009 07:57 PM
mgabriel
Dec 11, 2008 11:53 PM
ibncalb
Jun 2, 2005 09:02 AM
mke137
May 9, 2005 04:52 PM
