am I KO'd
Old 04-16-2011 | 04:46 PM
joenapier's Avatar
6th Gear
Default am I KO'd
What do I do now?
This is between cylinders 1 and 3 on the BLOCK!
Old 04-16-2011 | 05:16 PM
sleepercoupe's Avatar
TKO'ed
Start browsin the junkyards
Old 04-16-2011 | 05:45 PM
photocrimes's Avatar
Not worth saving. I could weld it and then deck the block but chances are the heat from the weld would release the sleeves. So you would look at a resleeve too. Cheaper to find a boneyard motor to rebuild.
Old 04-16-2011 | 08:09 PM
J-B Weld Company - World's Finest Cold Weld - Don't Scrap It! J-B Weld It!
What do you have to loose?
Try it and see what happens.
Fill it in, smooth is out, put her back together and drive it until it blows.
In the meantime look for a donor.
Wait, what year truck and where are you located?
Old 04-16-2011 | 08:24 PM
JumPeR04's Avatar
second that one spike
Old 04-16-2011 | 08:45 PM
jbm6287's Avatar
wow, not good sir... Build the new engine to be a 300 stroker. I plan on starting my 300 stroker build in the next couple weeks, i think i have a donor engine lined up
Old 04-16-2011 | 10:21 PM
Dodger's Avatar
forgive me if I am wrong, but from my computer, it looks like a broken head gasket. Nothing to get to upset over, just order a head gasket set and bolts.
Old 04-17-2011 | 06:58 AM
jdracersc's Avatar
I'm with Spike on this one too. JB Weld it and look for a donor rebuild in the meantime. I mean if your in a pinch and need the truck ASAP. Good luck
Old 04-17-2011 | 08:33 AM
thehun's Avatar
wrong his missing a chunk of aluminum
Old 04-17-2011 | 09:01 AM
Dodger's Avatar
My laptop screen is not the best, I guess if my rover stopped taking all my money I could get a new one. Well I hope you find a good deal on a new engine
