another lube question
Old 07-13-2012, 10:10 AM
drdeadchef's Avatar
Thumbs up another lube question
EXACTLEY.............
how mant grease nipples are ther on my disco and where are they???
Pics of the obscure ones would be great
Phillip
'96 disco 153k
Old 07-13-2012, 10:42 AM
Discolife's Avatar
HEHE you said nipples
Old 07-13-2012, 10:48 AM
Jake1996D1's Avatar
Each drive SHAFT should have 3 NIPPLES. After you grease your NIPPLES make sure to oil your swivel *****.
good luck
Old 07-13-2012, 05:28 PM
drdeadchef's Avatar
you guys are killin me LOL
Old 07-13-2012, 06:04 PM
Grease your NIPPLES each and every oil change and after wading in deep water, oil your ***** at least once a year.
I prefer to grease my ***** every 6 months.
Old 07-13-2012, 06:42 PM
Bkreutz's Avatar
TMI
Old 07-13-2012, 08:20 PM
BTW, also save some spray lube for each end of the hood latch cable. Real blast when it breaks off.
Old 07-13-2012, 09:48 PM
XCELLER8's Avatar
the air conditioner has nipples too, but dont grease them....just quick pinch or flick will usually do.
Old 07-14-2012, 07:11 AM
antichrist's Avatar
From the factory there are 3 zerks on the front propshaft, one on each u-joint and one on the slip joint.
On the rear propshaft there are 2 or 3 depending on if yours came with a rotoflex or cardan type u-joint at the rear diff.
It's possible someone has replaced the ball joints (tie rode ends) with the greaseable, so they would have one each.
Old 07-16-2012, 12:23 PM
ValveCoverGasket's Avatar
not to derail too much... but whats everyone using for a grease gun?
Quick Reply: another lube question
