another new issue
1. Get codes read at local auto store. They will know where the plug is. But FYI it is under the driver's side dash.
2. Fix whatever the problem is. Then worry about the light. If all you do is shut off the light then the truck will continue to have problems and if you want to clear it for inspection purposes don't waste your time. The computer will still store the code even if the light is off. You need a scanner tool to clear the codes.
Rover5150
Nov 4, 2007 04:43 PM
