Another Source for O2 Sensors
#74
#76
yeah after several start on & off cycles the ECM will clear the code if it passes muster. having a scanner with live data helps alot, helped me troubleshoot O2 sensor deaths by watching the ST/LT fuel trim data, rover was runing on default map settings, richer fuel.
#77
#79
its the Actron CP-9180. bought it 1 year from advance autoparts when it was like 1/2 off. its a good pocket scanner, you can record live data while driving and then download to the computer, i then export it to MS excel charts. it resets codes also, not abs though. i found a website download for scanner software that is more detailed, installs on ur laptop, but i have to find an OBDII port cable to connect to the laptop port.
#80
on
Some of the techno guys on here may know of a source.
I was using a new one at AA, but I did not have the manual nor did I know anything about doing te Live Data, but it did have a Live Data Screen.
They had to replace earlier one because someone burned it up by starting their engine, so I was hesitant to do that.
