Another Source for O2 Sensors
Old May 18, 2011 | 10:29 PM
  #71
Danny Lee 97 Disco's Avatar
Originally Posted by turf63
Just buy a set of metric line wrenches. They work perfect and you should have em in your box anyway.
What is a Line wrench?
Old May 19, 2011 | 06:33 AM
  #72
antichrist's Avatar
Something like this
I have a similar one for my Perkins injector lines, only it looks more like a deep socket with a cutout.
Old May 19, 2011 | 06:38 AM
  #73
turf63's Avatar
Damn. Beat me to it. I have a bunch. They're super handy to have.
Old May 19, 2011 | 06:43 AM
  #74
turf63's Avatar
When I googled them I called em brake line wrenches as I believe that was their initial intention but they work for lots of applications where box wrenches and sockets won't do
Old May 19, 2011 | 08:46 AM
  #75
Yes, those would definitely be good tools to have. Much better than an open end since it does grab more of the nut. The way the O2 sensor is slightly recessed can make it challenging to get on the nut squarely.
Old May 19, 2011 | 12:24 PM
  #76
revoRdnaL's Avatar
Yeah. Autozone won't clear codes anymore. So I was getting all geared up to do a negative terminal disconnect and the next time I got in the truck ('99) whammo. No light. I guess the ECM got what it wanted from the o2s and decided to play nice.
yeah after several start on & off cycles the ECM will clear the code if it passes muster. having a scanner with live data helps alot, helped me troubleshoot O2 sensor deaths by watching the ST/LT fuel trim data, rover was runing on default map settings, richer fuel.
Old May 19, 2011 | 03:23 PM
  #77
antichrist's Avatar
The wrenches in the set pictured are actually called Flare Nut wrenches.
Line wrenches are for removing diesel injector lines.
This is what mine looks like, couldn't find the photo this morning.
Old May 19, 2011 | 08:48 PM
  #78
Which scanner do you have?
Old May 20, 2011 | 11:26 AM
  #79
revoRdnaL's Avatar
its the Actron CP-9180. bought it 1 year from advance autoparts when it was like 1/2 off. its a good pocket scanner, you can record live data while driving and then download to the computer, i then export it to MS excel charts. it resets codes also, not abs though. i found a website download for scanner software that is more detailed, installs on ur laptop, but i have to find an OBDII port cable to connect to the laptop port.
Old May 20, 2011 | 03:46 PM
  #80
Some of the techno guys on here may know of a source.
I was using a new one at AA, but I did not have the manual nor did I know anything about doing te Live Data, but it did have a Live Data Screen.
They had to replace earlier one because someone burned it up by starting their engine, so I was hesitant to do that.
caymandrew
May 2, 2013 06:25 PM
Hyakku
Sep 17, 2010 08:49 PM
JAC
Oct 2, 2009 09:41 AM
Jawbox
May 19, 2006 02:44 PM
wildhorses
Oct 18, 2005 04:26 AM
