Anti Lock Brake Fuse Location
Old Jan 14, 2022 | 10:55 PM
disco96sd's Avatar
Default Anti Lock Brake Fuse Location
can someone give me a quick where is the anti-lock brake fuse location and the fuse number
thanks
Old Jan 15, 2022 | 07:33 AM
Toran's Avatar
The fuse is under the hood on the passenger side and is located in a small panel behind the battery. The inside fuse cover should be labeled.
Old Jan 15, 2022 | 09:42 AM
WaltNYC's Avatar
Fuse #5.
Page 125 of the pdf of the owners manual. That and many other manuals can be found in the Google link in my signature.
Old Jan 15, 2022 | 10:46 AM
JohnZo's Avatar
40A fuse disabled ABS Pump
Here's a photo.
Old Jan 16, 2022 | 05:06 PM
disco96sd's Avatar
thank you - you guys are the best
Old Jan 19, 2022 | 02:09 PM
disco96sd's Avatar
finally got a scan on my anti-lock light - shows CODE 26
anyone know that code ?
thanks
Old Jan 19, 2022 | 05:48 PM
WaltNYC's Avatar
Could be a brake switch failure....
https://www.rswsolutions.com/index.p...code-procedure
Old Jan 19, 2022 | 09:19 PM
disco96sd's Avatar
yep think i had to stomp on the brake super hard to stave off a crazy driver cutting me off in traffic - probably destroyed the brake switch with a super hard peddle stomp - guessing i need a new brake switch
Old Jan 20, 2022 | 10:55 AM
WaltNYC's Avatar
<$20 at Rock and a bunch of other places too. Thankfully it is one of those things you can just swap out to see if it works without breaking the bank.
Old Jan 21, 2022 | 11:54 AM
disco96sd's Avatar
yes thanks - ordered it $20 and got a cruise control cut-off switch too since they are both there
I have never changed them but it seems straight forward - if any one has any tips let me know
thanks
jemmicat
Sep 28, 2021 11:08 AM
Jason Torres-Morrow
Aug 8, 2015 12:55 PM
Pet
Aug 2, 2014 09:55 PM
gmscando
Apr 19, 2011 04:47 AM
thisisheaven
Jul 12, 2007 01:03 AM
