anti lock brake light
Old Sep 9, 2010 | 01:47 PM
  #21
tornado_735's Avatar
What relay do I have to pull? All I have are the little computer box, the diagnostic module, and the emissions reminder.
Old Sep 9, 2010 | 02:09 PM
  #22
okdiscoguy's Avatar
From what I am seeing, it looks light the front one to the right on the bank of relays. Not on the far right of the footwell, but in the bank that is mounted to the bar that folds down. K103 seems to be the warning light relay...
Old Sep 9, 2010 | 02:53 PM
  #23
You guys have my apologies...I must be inept or blind, because I cannot find this ABS relay. Does anyone happen to have a picture I can look at? My truck is pre-OBD2 if that matters...
Old Sep 9, 2010 | 03:05 PM
  #24
okdiscoguy's Avatar
Do you see the relay bar under the passenger dash? you take off a 10mm nut and the bar lays down to access the relays. Just to the left of your cruise ecu.
I added a pic. Looks like K103 has a brown pink and a black.
Old Sep 9, 2010 | 03:27 PM
  #25
My relay was green. I just felt for the relay to click when I turned the key on.
Gonna pull the codes now. Thanks for the picture!
Old Sep 9, 2010 | 04:24 PM
  #26
I am getting a code of 2-2. That's not on the list.
Figures lol
I cleared it three times and it's come back each time.
Old Sep 9, 2010 | 04:42 PM
  #27
okdiscoguy's Avatar
http://www.meritorhvs.com/MeritorHVS_Documents/mm38.pdf
HTH
2-2 Recirculation pump
operates continuously
(pump does not
switch off).
Check the recirculation
pump wiring, the pump
relay and the wiring
connections. Repair or
replace as required.
Old Sep 9, 2010 | 04:48 PM
  #28
HTH
(pump does not
switch off).
You know, take the disco out of the middle of your screenname, and that's you. You're an ok guy.
LOL Thank you very much I am going to eat dinner, then I'll read up on what to do.
Old Sep 9, 2010 | 04:55 PM
  #29
okdiscoguy's Avatar
ha ha. I have found a lot of info on these things, and getting the ABS back on was a bright day for me. Just nice to help someone else have the ah-ha moment I did.
That is from a wabco publication. Not for our specific units, so be careful testing if you are checking wires. Should point the solution a little closer...
Oh, and the base of the relay is blue. Most Rover relays are green or yellow...
Cheers
Old Sep 9, 2010 | 06:32 PM
  #30
Yeah, the relay (on mine at least) was a green one.
