Any particular reason?
Bearing analysis will tell you why they are failing. If you don't know what to look for, here's a good document. http://www.timken.com/en-us/products...ments/6347.pdf
I'm assuming you're making sure the races are seated well on installation.
The end float spec for the bearings is 0.010mm and if you use that spec you don't need a torque wrench or a hub nut socket that needs one. End float measurement is the way I do it.
Tom,
Great information. Is there some more detailed reference material available on this method?
What tools/measuring devices are needed? I would assume a good vernier or similar machinist tools?
RROJ
05-05-2011 12:43 PM
MichiganMan
10-29-2010 11:22 PM
testify
11-23-2009 04:38 PM
