Any particular reason?
Old Jul 30, 2011 | 03:15 PM
Originally Posted by Danny Lee 97 Disco
Also how often should they be repacked?
I say every 50,000 miles or everytime you change the rotors, whichever is sooner.
If you cheat on the rears you never need to repack them, you cant cheat on the fronts though.
I cheated on my rears.
Old Jul 30, 2011 | 03:48 PM
Banzai Jimmy's Avatar
With the adapter, how does one possibly use a torque wrench? I guess you need a standard type socket?
Originally Posted by Banzai Jimmy
The setup we have is just like the old Dana 30 axles - in fact, the Jeep spindle nut sockets work on our setups (and, of course, costs less).
Check out the sockets branded/advertised for Jeeps. Most are set up for a 1/2" drive and cost less than the sockets advertised for LRs. They're the same size.
Old Jul 30, 2011 | 09:59 PM
wheelgarage's Avatar
Yeah Danny...I didn't get the standard one. I bought an actual socket, since I wanted to be exact on the torque specs.
Old Aug 1, 2011 | 11:32 AM
LRD2&ME's Avatar
From: Oklahoma; where the winds come rolling down the plains.
I got my socket made at a local welding shop. It was cheap and it fits my 1/2 torque wrench. I re-pack my bearings before winter hits every year. Never had a bearing issue with any of my 4x4 vehicles.
Old Aug 2, 2011 | 04:38 PM
Danny Lee 97 Disco's Avatar
Live and learn, I will eventually get a real socket for myself. The adapter is a step above using giant pliers or a hammer and a chisel like some I read about.
Old Aug 2, 2011 | 08:44 PM
antichrist's Avatar
Bearing analysis will tell you why they are failing. If you don't know what to look for, here's a good document. http://www.timken.com/en-us/products...ments/6347.pdf
I'm assuming you're making sure the races are seated well on installation.
The end float spec for the bearings is 0.010mm and if you use that spec you don't need a torque wrench or a hub nut socket that needs one. End float measurement is the way I do it.
Old Aug 2, 2011 | 09:27 PM
Tom,
Great information. Is there some more detailed reference material available on this method?
What tools/measuring devices are needed? I would assume a good vernier or similar machinist tools?
Old Aug 3, 2011 | 07:40 AM
Jull's Avatar
RAVE page 501, there is a LR special tool needed
dusty1
Sep 9, 2016 10:50 AM
ashtray
Oct 14, 2012 12:36 PM
RROJ
May 5, 2011 12:43 PM
MichiganMan
Oct 29, 2010 11:22 PM
testify
Nov 23, 2009 04:38 PM
