Anyone need to replace their fuel tank vent hose?
This weekend I'm going to do r and r on my fuel tank.
Got parts to replace everything; fuel pump, vent hose and filler hose. I will try to post pics.
So I bought this:
Traveller® 3/4 in. x 14 ft. Fuel Hose - Tractor Supply Co.
And intend to cut it up for the vent line. It's 14 feet long, and after cutting and saving a spare I figure I'll have enough left over for another line.
If you are having as much trouble as I did sourcing 3/4" fuel rated hose locally let me know I'd be happy to help a forum brother out and mail it to you for cost of postage.
So I bought this:
I was having issues with the fuel pump stopping constantly a couple of fillups ago, and used the "pour fuel injector cleaner down the vent hose" trick. It seemed to work, until a couple of fillups later. Pump went clicking again, so I got home and tried something else. I turned on my compressor, fitted an air spray gizmo that had a small diameter outlet that fit down into the vent hose at the fuel neck (6 o'clock position), sprayed some compressed air down there, and no problems at the next fillup. 'Course it didn't occur to me that maybe shooting compressed air down the vent hose might not have been a good idea, but I figure if something is clogging it, that should've cleared it out, for now at least...
i had the problem with the tank being reluctant to accept fuel for a while. Could take 45 minutes to get enough fuel in the tank to go anywhere, and was intermittent. I always thought it was a sticky one-way rollover valve, the one that keeps fuel from flowing back out the filler neck in the event of a flipper. It never occurred to me it could be the vent hose. Cleared itself up, regardless.
Reviving this thread from the dead..... Any chance you could measure this up? I need to replace the vent line too. Technically, I could just repair it since the leak is not on top of the tank, but I figured it'd be cleaner to replace the entire length of hose.
marsyas
02-25-2021 08:11 AM
