Fuel Tank fill vent hose
Old Sep 30, 2014 | 11:01 AM
photo2u's Avatar
Default Fuel Tank fill vent hose
Friends,
I am repairing Fuel Tank Fill Vent hose in my 95 Discovery I W/O EVAPORATIVE LOSS.
I do not have the budget to spend the 55.00 dollars for the oem part. Does any one know the inside diameter of the hose?
Please advice,
G.
Old Sep 30, 2014 | 12:16 PM
HammerFit's Avatar
Originally Posted by photo2u
Friends,
Please advice,
G.
check this out https://landroverforums.com/forum/di...nt-hose-67696/
or do what I do....don't fill it all the way up I stop the pump at 18 gallons, much easier than replacing hose
Old Sep 30, 2014 | 12:35 PM
nuclearw's Avatar
3/4 in id, few places have this large size , carquest usually stocks it.. on mine i ended up using a 3/4in coolant splice and replacing half the hose the full length was about 30$
Old Sep 30, 2014 | 01:34 PM
photo2u's Avatar
Hello Nuclear,
Thanks for the size info. I will get the hose from a local supplier. He sells by the foot. He quoted me 3.70/feet I will get two feet and use a metal adapter with clamps instead of dropping the tank.
Thanks,
G.
Old Oct 2, 2014 | 12:51 AM
Ed Z's Avatar
I got some chemical safe 3/4" hose off eBay... I don't want to have to replace that hose ever again so I got a type that is highly resistant to most all chemicals... It was much like this stuff...
Hydraulic Suction Hose Gas Diesel Fuel 3 4" per Ft | eBay
Old Oct 2, 2014 | 09:40 AM
photo2u's Avatar
Thanks for the info.
The omg hose is so expensive that is criminal. My supplier will sell me the same hose for less than 15 dollars. The reason for failure in my truck was due to the bad clamp used at the factory.
Old Oct 3, 2014 | 08:08 AM
Ed Z's Avatar
The hose is only $6 per foot... 3 feet of it would only be $18...
Old Oct 7, 2014 | 10:04 AM
DiscoBlanco's Avatar
Don't be cheap and lazy. Do the whole thing. It's not a matter of IF the hose will fail on the tank side; it's a matter of when.
I'll even send you the 4 bucks.
Old Oct 9, 2014 | 11:39 AM
photo2u's Avatar
Who in the hell you think you are. I am not cheap and lazy. You can keep your stupid comments to your self sir.
Old Oct 13, 2014 | 04:02 PM
Because I did what you plan to do and the other end of the hose went in the dead of winter. do what you want. I can care less.
Travelor
Dec 4, 2022 09:51 PM
geek_IM
Mar 31, 2018 03:03 PM
JustTani
Oct 9, 2014 01:42 PM
Landzu
Sep 13, 2008 11:32 AM
djb
Freelander
Apr 9, 2006 03:01 PM
