ARB winch options
Old Apr 26, 2014 | 09:25 PM
Halftrack's Avatar
7th Gear
Default ARB winch options
Hello All,
Just recently installed a used ARB Bull bumper on our D1. ARB recommends the Warn XD9000 winch, what other winch options will fit this bumper?
Thank you.
Old Apr 27, 2014 | 08:24 PM
fishEH's Avatar
No clue. Measure the bolt pattern and the opening for the winch and compare it against different winch dimensions.
Old Apr 27, 2014 | 09:44 PM
jafir's Avatar
http://www.arbusa.com/uploads/PDF/ac...Discovery1.pdf
Old Apr 28, 2014 | 06:50 AM
MM3846's Avatar
id recommend a used M8000.
Old Apr 28, 2014 | 07:48 AM
TOM R's Avatar
Aren't most winches the same bolt pattern?
Old Apr 28, 2014 | 08:11 AM
MM3846's Avatar
pretty much everything except a few ramseys and superwinchs i've seen... but those were real old ones. 4.5" x 10" is the standard size in case anyone was curious...
Old Apr 28, 2014 | 11:41 AM
coors's Avatar
I'm running a 12k Harbor Freight Badlands winch. Bolted up fine. I just had to "clock" it to fit the way I wanted it.
There's a thread on here where members can write reviews on their experiences with the HF winches.
I highly recommend cracking the winch open cleaning out the factory grease (if there is any) and re-applying marine grade lube. At the same time, go ahead and waterproof the control box.
DiscoRover007
Aug 14, 2015 11:46 AM
blast20
Feb 15, 2010 10:25 AM
colbywan
Jun 25, 2009 06:36 PM
Sooners
Jun 21, 2008 08:18 AM
uziduzit
Aug 17, 2007 09:08 PM
