aux port on intake manifold??
Old 08-17-2014 | 01:59 PM
TOM R's Avatar
Where did you find a reducer that size?
Old 08-17-2014 | 02:52 PM
MM3846's Avatar
i went to home depot with the plug and the temp sender and found what i needed. its a pipe flange to compression fitting adapter (3/4 SAE to 3/4 NPT), then a 3/4 to 1/8 NPT reducer, then the sender.
Old 08-18-2014 | 10:41 AM
TOM R's Avatar
where in home depot did you find that? I tried home depot and lowes and they act like I am retarded for asking for an sae to pipe thread adapter
Old 08-19-2014 | 05:46 AM
MM3846's Avatar
the plumbing section... there is no specific NPT to SAE adapter... but flange end pipe fittings are SAE thread, and compression fittings are NPT thread. or at least the ones i bought are.
Old 09-02-2014 | 12:34 PM
TOM R's Avatar
That is not male pipe flange
It is flare thread
Here is the pic top is plug bottom is adapter 1/2" male flare to 3/8" pipe thread to fit the switch I bought, I actually ground off the nipple on the pipe adapter it is not needed here and gets the temp probe closer to the coolant
Install looks very clean, now onto the injectors
Old 09-02-2014 | 03:14 PM
fishEH's Avatar
Ok, so question. The plug that came out looks to have an obvious taper whereas the 1/2 flare end appears to have no taper. So how is it sealing? Just a lot of tape or thread sealant?
Old 09-02-2014 | 03:23 PM
TOM R's Avatar
I put tape on it and tightened it all the way, no idea on mine till I get the engine fixed, think the original plug just looks tapered in the pic but is not
Old 09-02-2014 | 03:34 PM
HammerFit's Avatar
where did you find these?
Old 09-02-2014 | 05:13 PM
fishEH's Avatar
I think this is the nipple. Pardon the crude cell phone edit.
Old 09-02-2014 | 06:35 PM
TOM R's Avatar
adapter was lowes plumbing isle, sensor was ebay 175*-185*
fish yes that is what I ground off, saw no need for it, plus gets the probe in closer
fish think it is all that gunk in the threads making that old plug look tapered
link to fan switch
http://www.ebay.com/itm/171236949794...%3AMEBIDX%3AIT
Quick Reply: aux port on intake manifold??
