Axle Carrier Question
Old Nov 2, 2014 | 02:08 PM
Shiftonthefly1's Avatar
Default Axle Carrier Question
I have a broken axle shaft on my RRC. I'm posting this here because it's the later Disco axle not the 10 spline. Or so I'm told. I haven't opened it up yet. My problem is that the snapped off end won't come out of the tube. I tried a along magnet with no luck. Since I don't know the severity of the brake I wouldn't mind checking it out and cleaning it all up anyway.
My question is can I simply unbolt the assembly from the axle housing? Or will I have to disturb the bearings/preload? I'm reading the manual and it's not forthcoming with information about pulling it out and putting the same parts right back in.
Finally I'm assuming clean with RTV sealant is ok? I don't see a gasket in place now.
Old Nov 2, 2014 | 02:21 PM
jafir's Avatar
When I replaced my 10 spline with 24 spline I wanted to keep the old axle assembly, but it's too heavy and awkward to move assembled. So I unbolted the swivel ***** and unbolted the diff so that I could put it all in my shed. The swivel housings, brakes, swivel *****, cv joints, axle, etc all complete are still pretty heavy though. I did have the calipers off because I wanted to swap them onto the new axle.
Old Nov 2, 2014 | 02:23 PM
jafir's Avatar
Never mind. You're talking about rear.
Just pull the good shaft too and you should be able to unbolt the diff. Rear is much easier.
Old Nov 2, 2014 | 02:31 PM
Gimebakmybulits's Avatar
Pull driveshaft, axles and unbolt carrier to remove.
Old Nov 2, 2014 | 02:47 PM
Awesome guys thank you very much. Pulled the other side out confirmed the 24 spline axle. Good deal.
Old Nov 2, 2014 | 03:48 PM
Well.....
Any bright ideas on how to get that out? Pliers and whacking the housing art working..dammit
Never mind. I realized I'm looking at the other end of it thru the other side. Took some persuasion but came out
Old Nov 2, 2014 | 03:51 PM
jafir's Avatar
If you flip it around, you can probably get a punch past the cross pin and drive it out from the other side.
Old Nov 2, 2014 | 03:54 PM
Drill it and use a easy out to make a handle to pull on. Or drill it and tap the hole thread a bolt in and use that as a handle.
I've always gotten them out with a strong magnet
Old Nov 2, 2014 | 05:34 PM
fishEH's Avatar
You should be able to tap it through from the other side.
Originally Posted by Shiftonthefly1
Well.....
Old Nov 3, 2014 | 09:34 AM
Fish you mentioned in another thread that it's not hard to set up a diff in the garage with about 100 bucks worth of tools.
I'm thinking I have some nice bearing noise.
