axle problem?
Old Oct 12, 2010 | 07:44 AM
antichrist's Avatar
It doesn't sound like it was rebuilt, it sounds like the entire axle assembly was replaced.
You could have a blown hub seal which will get it all over the inside of the wheel. That's my guess since the centrifugal force spreads it around. A leaking swivel seal just drips on to the wheel. Of course if the swivel seal is leaking a lot then it can look like a bad hub seal then check it frequently.
Get a couple cans of brakeclean and spray the swivel down good.
Also look up in behind the wheel and see if it's all over your rotor, pads and inside of the wheel. If it is, then it's the hub seal.
cationmoted
Oct 19, 2012 07:39 AM
Speed racer
Oct 11, 2008 10:56 PM
sanmigmike
Aug 24, 2006 03:37 PM
DiRanged Rover
May 26, 2006 12:39 PM
DiRanged Rover
May 24, 2006 07:36 PM
