back door problems
Old Jul 28, 2010 | 12:58 PM
bardel's Avatar
Default back door problems
Hi evryone, Have a 1999 discov back door will not open. Took it a part to find the outside handle disconeted. The lock seems to work. Is there a way to get it open. Thanks
Old Jul 28, 2010 | 08:50 PM
Have you lubed the rear handle?
Will the handle move at all from the outside?
Old Aug 2, 2010 | 05:08 PM
bardel's Avatar
Hi spike555. Yes the handle moves freely. had to fix it though. it wasnt hook up inside the door plastic clip broke.
Old Aug 2, 2010 | 05:26 PM
So it is fixed now?
It was a broken clip inside the door?
Old Aug 2, 2010 | 05:52 PM
bardel's Avatar
No spike it still dosnt work. but handle moves freely
Old Aug 2, 2010 | 05:53 PM
bardel's Avatar
the power lock works all so or gos up and down anyway
Old Aug 2, 2010 | 05:56 PM
bardel's Avatar
there is no place fo0r a key in the back for the door that i can see
Old Aug 2, 2010 | 06:18 PM
okdiscoguy's Avatar
Make sure something else didnt slip off inside. I take it that you can get it open from the handle inside? Also, if you have no place to insert a key, you have a series 2. Might check that forum.
Old Aug 2, 2010 | 06:19 PM
OK, you have a DII then.
DI's have a key hole in the cargo door.
I bet your child safety lock is on.
Old Aug 3, 2010 | 02:24 AM
Spencerfitch's Avatar
back door problems..
lubing the handle..
ok ill go grow up now
