back door problems
Hi evryone, Have a 1999 discov back door will not open. Took it a part to find the outside handle disconeted. The lock seems to work. Is there a way to get it open. Thanks
Make sure something else didnt slip off inside. I take it that you can get it open from the handle inside? Also, if you have no place to insert a key, you have a series 2. Might check that forum.
