Bad fuel pump?
Old Mar 12, 2011 | 07:16 PM
rover11's Avatar
Default Bad fuel pump?
I have a 97 Land Rover Discovery. I haven't driven it in a week or so. I took it out today and could not go over 15-20 mph. It sounded like my fuel pump was knocking? Is this a common problem when the fuel pump is bad?
Old Mar 12, 2011 | 08:35 PM
kenk's Avatar
I've never heard of that, but suppose possible something may be loose in there?
Could it be the noise was coming from the exhaust at the tail end, like a miss or sputter?
Old Mar 12, 2011 | 09:32 PM
rover11's Avatar
I'm not sure. Its a brand new exhaust system. What else could be causing the problem I'm having if it isn't the fuel pump?
Old Mar 12, 2011 | 09:52 PM
Chris-bob's Avatar
If it started right after the new exhaust was installed, then the exhaust is the problem.
Old Mar 13, 2011 | 12:41 AM
roving patrol's Avatar
maybe, the purge valve? Have the codes read?
Old Mar 13, 2011 | 11:34 AM
rover11's Avatar
It was happening before the exhaust was installed.
Old Mar 13, 2011 | 11:36 AM
rover11's Avatar
I remember when I had the exhaust put on and the computer reset the mechanic said something about the fuel pump but I cannot remember exactly. It was something about the float maybe?
Would it say it was throwing a code?
Old Mar 13, 2011 | 12:21 PM
Dodger's Avatar
check your fuel pressure. It should be between 34 and 37 psi a idle. Could also be a bad fu pressure regulator.
Old Mar 14, 2011 | 10:41 AM
rover11's Avatar
It is weird. I started the truck yesterday and it drove fine. Stupid Land Rover!
Old Mar 14, 2011 | 10:52 AM
Cosmic88's Avatar
Rover11-- it must be the F U regulator Dodger was talking about. Nothing to do with the Fuel Regulator but that other, special F U regulator which meters out an occasional F U as preprogrammed by those fine chaps at Solihull.
I think Lucas makes all sorts of F U components too. I think I'll see if I can order up a "Special F U Vehicles" badge for my rig.
