bad heads help
Old May 21, 2013 | 11:06 AM
TOM R's Avatar
Default bad heads help
ok got the bad news I expected, both heads are warped 75 thousands or .075 well beyond what the shop considers cuttable by the specs they have and we do not know if they were cut before can these be salvaged or do I need to look for another pair?
shop asked if I knew what the stock specs for the heads were so they could check the height/ thickness
Old May 21, 2013 | 11:23 AM
pinkytoe69's Avatar
The specs are somewhere in the rave.
Old May 21, 2013 | 11:44 AM
and here. Might be time to fly low and fast with the partz vulturez at the boneyard. Many yards will be having a Memorial Day sale.
Seems like limit is 20 thousandths from new.
File Type: pdf
Old May 21, 2013 | 11:47 AM
TOM R's Avatar
thanks buzz I will run this over to them, do all heads fit ? I can probly get a set off a d2 or range rover
Old May 21, 2013 | 11:50 AM
Let us get some other opinions on that fine point. The 98 is a GEMS engine, was also in Range Rovers. You probably would not want to get heads from an SAI truck as an example.
Old May 21, 2013 | 01:29 PM
TOM R's Avatar
ok I printed the page and went to the shop, heads mic as new uncut so they did some calculating and believe they can mill and still be in lr spec
guess I misheard on the phone and he said 7 and 5 thousands not 75 so hopefully I won't be buying heads once they mill and remic
btw thank you very much for your help buzz
Old May 21, 2013 | 10:49 PM
zigzag3141's Avatar
Ive got a complete engine assembly still sitting around after my swap a few months back. One of the cylinders was discolored but the block pressure tested okay. Just didn't want to take the chance given you cant perform the pressure test at temp. Heads are in good shape. PM me if you need them. I have everything crated and ready to go from Houston, TX.
starcraft1
Nov 13, 2011 08:14 PM
scubaman
Nov 30, 2009 01:04 PM
oljohnboy
Sep 14, 2009 03:01 PM
JBEGIN
Jun 27, 2009 12:38 PM
Bene
ROAMING WITH FRIENDS
May 11, 2005 04:33 AM
