Base idle setting
Old Jan 29, 2015 | 04:21 PM
jafir's Avatar
Does your engine have a distributor?
Old Jan 30, 2015 | 09:00 AM
Kobus van Eeden's Avatar
Hi Jafir
Yes the engine have a distributor, check the vacuum advance it is working the gap is set correct the pipe from the distributor is not leaking. thx
Old Jan 30, 2015 | 09:03 AM
Originally Posted by TOM R
do you have a scanner that shows live data? if so what is the tps with key on?
Hallo Tom
Unfortunately not, I did bought one I am still waiting for it
Old Jan 30, 2015 | 09:06 AM
jafir's Avatar
If you've got a distributor, you probably don't have OBD2, so you'll need something special to talk to the Lucas engine management, to get live data.
Like this: https://code.google.com/p/rovergauge/
Old Jan 30, 2015 | 09:09 AM
Originally Posted by MonteroMan
Wys jou hoe gou leer mens swak taalgebruik aan... ek kon dit seker baie beter gestel het
Wou sommer net kontak maak en het bedoel jy moet 'n boodskap op die "personal message" fasiliteit stuur.
Andries
Andries, verduidelik hoe doen ek dit verskoon ek is maar dom met die goed
Old Jan 30, 2015 | 09:24 AM
This model that I have does have obd2
grandkodiak
Apr 16, 2011 10:21 AM
Rover Chris
Oct 3, 2009 04:22 PM
meltdowndave
Apr 19, 2008 09:50 PM
chenderson
Sep 21, 2007 07:37 PM
don_r6
Aug 28, 2007 04:09 PM
