Battery? Alternator? Wiring?
Old Oct 9, 2012 | 08:19 AM
Michael M. Koch's Avatar
Have you checked your serpentine belt? There are a few discussions on the forum about how easy it is to incorrectly route the belt when changing it. Also if it's old it could be stretched out, losing tension. Either of which, in theory, could cause your alternator pulley to slip and run slow, thus not operating to its full potential.
Old Oct 10, 2012 | 10:58 AM
FieryRebel28's Avatar
I just replaced the alt and the truck still dies right after a jump. The belt is good and spinning the alt just fine. I'm stuck...I guess I'll check the connections...pita...
Old Oct 10, 2012 | 12:50 PM
If it keeps running once jumped with the cables on, then dies when you remove them, does sound like alternator, cables, or that 100 amp fuselink in the underhood box. The front two cables in the underhood box bring the alternator over to the rest of the truck.
JumPeR04
Dec 17, 2009 07:57 PM
mgabriel
Dec 11, 2008 11:53 PM
joshsrover
Apr 2, 2008 11:03 AM
kjj0506
Sep 3, 2007 08:01 PM
Claree
Nov 19, 2005 11:08 AM
