Battery Tray Restore
My 97 Disco's battery tray area was in poor condition. The enamel had wore away exposing the metal which eventually rusted.
I cleaned the area with degreaser, sanded it by hand, applied rust remover, sanded it by hand again, detailed with rotary tool, cleaned again, and finally applied VHT chassis paint.
Enjoy
Enjoy
The split plastic offers some protection (better than nothing) but allows stuff to still get to the wires (liquids, heat,etc). On a couple of the missile programs I worked on, we had something I had never seen before. It was called centerline tape (due to a stripe down the center). This material had no adhesive, it bonded to itself thru a self-vulcanizing property based upon molecular migration. Within moments of coming into contact with itself, it would not come loose. In a short time frame, the layers no longer were individual layers but became a solid mass. We used it in high heat environments like the tailcone area of the MX Missile.
I have since seen it more commonly available. It provides excellent protection for heat, abrasion, and provides excellent electrical insulating properties. Any of you military techs seen any around? It would be great to find that at a military surplus sale or any commercial distribution source.
Are any of you guys familar with it?
You can get the corrugated plastic sleeve with just a razor split down one side, does not let in as much as the spiral wrap. But you have a lot more connectors that will cause problems with water / salt issues before these wires. Might want to look at dielectric grease as well.
carlitonsky
Appearance & Camping Set Ups
Nov 27, 2008 11:59 PM
maduwage
Sep 3, 2007 08:15 AM
