Battery warning light
Old Jun 2, 2014 | 09:38 PM
TOM R's Avatar
Alt on these are crap you will get good at it
Old Jun 2, 2014 | 09:45 PM
dusty1's Avatar
Mean green offers an upgraded one that fits our trucks
Old Jun 7, 2014 | 11:54 AM
HammerFit's Avatar
Default Crap not again
Exactly one week after installing new alternator and battery went out to crank it today, dead battery! Checked all the connections, no corrosion all tight. Cable from battery to frame looks good. Cranked fine yesterday. Put battery charger on battery, it reads around 35%. Lights and accessories working. Gonna get a volt meter when wife comes and run through RAVE checklist.
Old Jun 8, 2014 | 09:56 AM
ihscouts's Avatar
I'd start looking in the area of the transmission since that was recently disturbed. Wasn't a problem before they changed it.
Old Jun 15, 2014 | 11:03 AM
HammerFit's Avatar
This is driving me nuts! Went out this morning and battery dead again! I had the shop check for voltage drops for 2 days. Nothing. Final determination, my new battery is defective. Took it back to where I bought it no questions asked, put in new battery. (2nd new battery in less than 2 weeks) I asked the salesman, is this normal brand new battery defective. He said yes sometimes we get in bad batch. Hmmm. Now newest battery is dead. Same brand same store. What he said about a batch being bad rings in my ear.
Here's strange part or at least to me. Put multi meter on it the day I brought it home and everyday after. It reads almost 12 volts. Everyday same reading. Today it's dead same reading just under 12 volts. Put battery charger on it reads only 35% charged.
Not sure what to do at this point. Does it sound like I have another defective battery?
Old Jun 16, 2014 | 03:52 AM
No. A defective alternator. Try these:
charge battery or replace with another
Volt meter across battery should be 12 - 13 before you start truck.
Switch on head lights - battery should maintain volts above 11 The head lights are a load test.
Lights off and crank truck. Volts should go up to 13.8 - 14.4 volts.
Now turn on head lights and everything else like AC, wiper, radio, aux lights - volts should drop a little but not below 13.2 (minimum charge voltage).
You can also verify good battery ground by bridging a jumper cable from (-) battery to alternator case (not terminals). If volts go up you have found a bad connection causing a "voltage drop". The voltage drop of the battery terminals can be measured by putting one meter lead at center of post and then reading along the connector or cable. Ugly connections sometimes drop a volt or more right there.
The alternator is a 3 phase AC generator with diodes that convert that to DC. If a diode(s) go out you can have a 33 amp alternator instead of a 100 amp one. So it looks ok at idle, but put normal loads on it and it "steals" from the battery (your reserve minutes) and you end up with dead battery. With everything "on" my 97 D1 draws 85 amps from alternator. And maintains 13.2 volts.
Now you could have a parasitic drain that remains after you switch off the engine. Weird things have included rear door subwoofer amp staying on, etc. On non-meter trick is to use a brake light bulb and hold in series with battery lead and truck off. A big drain will make filament glow brightly.
Warning - Rover alarm systems don't like power switching on/off with hood open, they can remember their last condition and wake up believing they are under attack, at which time the immobilze the ignition etc. Best to hold down the alarm switch or disconnect it like many do (hoping that some one will steal that posh pile of pre-owned sheet metal).
Old Jun 16, 2014 | 12:56 PM
HammerFit's Avatar
So far this is what I have: battery reading engine off 12.45v headlights on engine off 12.22 engine on no lights 13.58 engine on all accessories on 12.73
Are these number telling me my new alternator is not doing job?
Old Jun 16, 2014 | 01:10 PM
MM3846's Avatar
what brand battery? and what brand alt? it seems that they both arent doing a "good enough" job.
Old Jun 16, 2014 | 01:21 PM
HammerFit's Avatar
autozone
Old Jun 16, 2014 | 03:14 PM
HammerFit's Avatar
Checked it again a few hours later and it is now 12.2 so something is draining the battery while it is at rest
