Bias Valve/Proportioning valve Leak!!!
Old Feb 6, 2016 | 09:00 AM
1995D1's Avatar
Default Bias Valve/Proportioning valve Leak!!!
I have a steady leak from my Bias valve. Its coming from the rear(closest to firewall). what is under the cap that is put on from the factory? Is it just a plug or something i can pull out and reseal better?
thanks
Old Feb 6, 2016 | 05:06 PM
Gimebakmybulits's Avatar
thanks
Is this the part you are talking about? If so just replace it.
Brake Pressure Reducing Valve - ABS On Land Rover Discovery
Old Feb 8, 2016 | 09:58 AM
drowssap's Avatar
yes, replace it
Old Feb 8, 2016 | 01:29 PM
jastutte's Avatar
x3 on replacing it. it's easy to do. i didn't even need to bleed the brakes after.
i picked up a used one from some guy parting out his D1. much cheaper than a new one.
Old Feb 10, 2016 | 01:22 PM
1995D1's Avatar
i understand i need to replace it.....they are not cheap by any means. There are no D1's at the boneyard at the moment either so a used one is not an option. I was just wondering if that plug on the back can be pulled and a new o-ring installed or something along those lines. I need my truck and I hate to say it but i just dont have 300 bucks at the moment.
Old Feb 10, 2016 | 01:30 PM
jastutte's Avatar
do a quick search for Paul Grant and/or Will Tillery.
both guys sell used LR parts. they should be able to hook you up.
Old Feb 10, 2016 | 02:24 PM
number9's Avatar
Default Math Skills
How did $215 turn into $300?
Old Feb 10, 2016 | 04:17 PM
fishEH's Avatar
Get an adjustable proportioning valve from Summit and replumb the lines.
Old Feb 11, 2016 | 03:17 PM
ihscouts's Avatar
Rovahfarm has em for $179......
Old Feb 12, 2016 | 10:13 AM
1995D1's Avatar
fishEH thats what im in the process of doing. I found one for 75 bucks and comes with an adjustable valve so i can get the brakes dialed in right. thanks for the help guys
