Body lift
Old Apr 24, 2011 | 06:32 PM
  #21
thehun's Avatar
anyone have experience with lucky8 1.25 body lift
Old Apr 24, 2011 | 06:49 PM
  #22
rover11's Avatar
What kind of affect with the body lift have on your steering linkage etc.
Old Apr 24, 2011 | 08:10 PM
  #23
Spencerfitch's Avatar
Do not waste your money on prefabbed bodylifts. It's easy to do yourself. I did 2" and one 1" all you need is the spacers amazon has them
Pretty cheap and the longer hardware. No adjustment to steering. Just loosen the Nut on the steering shaft before you lift and then tighten after.
Again all that's needed is hardware spacers and a drill (relocated radiator mounts)
Old Apr 25, 2011 | 06:45 AM
  #24
antichrist's Avatar
You need more than 2" body spacers to do it right and safely.
Old Apr 25, 2011 | 10:32 AM
  #25
sleepercoupe's Avatar
Well, its not exactly what your after but its got a 1" body, 3" RT Springs, and 2" Spring spacers, but also has ext. arms, ext. lines, drop pitman, GB shafts. As far as electrical or shifter extensions it has none, the only problem I've encountered is when its SUPER flexed it will pop out of Low/High on the DL side..
Its got 265/75's I think the front of the rear tire would start getting close to interfering with my sliders if I went to a much larger tire.
SkyHigh95
Nov 11, 2010 08:29 PM
Gordon Bombay
Apr 28, 2010 11:37 PM
bubblehead5
Jan 31, 2010 05:51 AM
sharp21
Oct 21, 2006 06:54 PM
JRdisco1
Feb 10, 2006 12:34 PM
